ONEX #54 Web Site
Date: 6-3-2013
Number of Hours: 4.00
Manual Reference: E01
Brief Description: Panel switches and breakers
Added the slip indicator to the right side of the panel.
Added a 4-position selection switch for the Westach EGT/CHT instrument. All cylinders can be wired for EGT/CHT but only one pair can be shown at a time.
Added switches to the sub-panel and breakers to the instrument panel. From the center moving left the switches are: master (SP), mags (DP), ignition (SP), stobes (SP), start (SP momentary), radio (SP), transponder (SP), navigation (SP), nav lights (SP), landing light (SP).
For the switched circuits that need a circuit breaker, the corresponding breaker is located above the switch.
The switches are the order from right to left I'd expect for startup, and move from left to right for shutdown. It would have been more logical to start from left to right, but I wouldn't have been able to orient the breakers above their corresponding switch. One benefit is that the most important switches are furthest from the trim knob so they don't get bumped by mistake while trimming.
Switches and breakers
